pngaudioguy
I've been reading for awhile now on this forum and other places trying to learn what I need to know for my upcoming project. Realistically, timeline is probably not until about a year from now. Timeline isn't super critical, so if budget requirements mean pushing the timeline back, that's ok too. I'd rather spend the money and do it right once and enjoy the benefits for 10+ years.
I'm planning to get the equipment, get it mounted, do low voltage wiring, then hire an electrician for tie in.
Project phases by importance if I have to spread it out:
I'm thinking that the LF280K type battery will be my storage, with a 48V target (16 cells). I understand they actually run around 51V, for about 14kWh of stored juice: ~4+ hours of backup of typical load. I'm pretty sure I want to use the Batrium BMS K9 system for management.
I can fit 10 of the REC Pure-RX 470 panels on the one roof surface I can use for solar, which would generate about 4kWh for the 4 or so hours of full sun that surface gets here in Northern MA.
Things I'm trying to decide on:
Inverter (Schneider XW Pro, Outback Radian, other?)
Do I need a separate MPPT, or can I use the function from the inverter if I'm using a BMS like Batrium? I feel like it would depend whether I go with micro-inverters at each panel, or a string inverter.
Grid cutoff
What provides the full grid disconnect for safety when the grid is out while still powering the house from battery/solar/generator? I know Schneider makes a BCS, would I need something like that as well?
Will be mostly installed in the semi-finished side of the basement with dry walls and sealed concrete floor. Have wall space on the outside next to the main meter for the house as well, which is where the pad for the generator will eventually go.
I'm definitely interested in cost effective ways of doing the whole system, but don't want to cut corners so I'm looking forward to any and all suggestions for well known vendors, equipment combinations, etc. Thanks in advance!
- Battery backup and inverter/charger
- Solar panels
- Generator
- Needs to be able to send loads to my panel and the grid when solar output is greater than load during the day.
- Either directly or through external MPPT need to charge batteries as well.
- Would like to not have outage that requires setting clocks on microwave etc when grid drops - is the 50-100ms changeover on the Schneider units enough to drop the clock? Is there a better answer?
- At night, as long as the batteries are above the discharge threshold, I'd like the system to power the house from the battery when possible, then recharge the next morning prioritizing solar, then grid if not back to 80-90% SOC by late afternoon. Otherwise, maintain charge and power the house from the grid. (Night power usage typically floats around 500W, so assuming 80% DoD that's easily more than 12 hours runtime.)
- Eventually, I'd like to add a generator for battery charging when the sun and grid are both gone - we have winter storms and random outages and I don't want to be worrying about that when I'm older.
Grid cutoff
