CuriousDIYr
- Nov 30, 2020
- 2
Many of the batteries I have been looking at, such as the SOK, have a maximum 100 Amp @ 12V discharge rate. However, an automotive diesel starter motor can draw up to 650 Amps for a short duration. I am concerned that if I apply an SOK to this use case, it will not be adequate to start my truck.
Also, will the battery management system cut the circuit if it exceeds 100 Amps, or do I potentially damage the battery? I ask, because my truck has two batteries, perhaps one battery could be a lithium back-up and the lead-acid the primary starting battery.
