LittleDaB
- Dec 10, 2020
- 18
Is it just me?...what am I missing?
Just three months ago I was quite happy with my lead acid batteries, especially considering they've been good to me since 2005 (cottage system for weekends and some vaca’s). But I had to move on, I had become sooo tired of the maintenance!
Lifepo4 was on the radar, but wait, bms...WTF is a bms! So needless to say, this newbie has had a steep and rapid learning curve. I wasn't planning on getting a bms but decided it's for the best...but is it?...the more I read the more informed I become and the more questions and complications arise. So I picked up an Ant 16s 320A bms for my 24V BYD pack...but instructions, what instructions, just a bunch of diagrams online...but I got it going Bluetooth and all (Ant app on iPad) connected instantly!!...Soooooo surprised! I've come to know my newly acquired battery pack quite well, well enough to know it's limitations by way of many charge/discharge cycles and notes. Basically, anything below 3.0V/cell and above 3.4V/cell and things can get really wonky without a bms, 27.2V overall pack voltage and you’re looking for trouble!...but incredibly predictable and stable between 24V and 27.2V...for now.
So I'm trying to set all of the peramaters, and being so new to all of this, I was finding it very confusing...
still finding it confusing...I had no idea you needed sooooo many parameters. Some are no brainer’s, or so I thought. For example, “Balance start volt” which I interpret as the set point at which balancing begins...Not true, “Balance limit volt” is where it all starts...hmmmm! Ok, moving on to protecting cells, high and low. I would have thought that Cell Low Protect meant the voltage at which discharging would stop...Not so! That's Cell Low Recovery...hmmmmmm!! How's about Cell High Protect...to protect certain cells from going to the moon...Not so!,,,that would be Cell High Recovery...again hmmmmm!!! Now Total Volt High Protect and Total Volt Low Protect, they actually work as stated, shuts down charging at a specified pack voltage and shuts down discharge at specified pack voltage...all good. There are sooo many other examples of this messed up terminology throughout. So I ask U...all of U, any of U...what am I missing? I have pretty much sorted out 80% of the ProtectParameter(s) as well as the TemperatureParameter(s)...really messed up and potentially catastrophic in my case (November to April). Listen to this: “Chg Temp Low Protect” I would have assumed that this set point would stop the charging to protect from the hazards of freezing...No, that would be “ChgTemp Low Recover”. So I set Low Recover to 1 degree C and Low Protect to 2C...works beautifully. But it’s backasswards! The BatteryType Parameter...easy I think. The BMS Hardware Parameter...who knows! and the rest is all Chinese to me.
So for the time being, and until I understand more I’ll keep the bms in play, perhaps only on the load side, when installed in the actual system. But for now, if anyone has ALL of the parameters worked out, please help, otherwise I'll be here for a long long time!??
