The internet is full of this statement and example (also in Will videos):
"Watt is instantaneous power. 1000W load running for one hour is 1kWh. "
So that means if all your loads sum up to 1000W then you need at least 1000W inverter.
All of this does not make sense to me.
If a device has rating of 1000W it means this is the average power consumed over a whole hour, right? it does not mean it will suck 1000W at any given second. because if it really a load that sucks 1000W as instantaneous power and it was running for an hour that means if we are measuring and recoding it every second it will be 1000Watt/Second which means 1000watt.sec * 3600 = 3600kWh and not 1kWh.
So why the whole internet takes the average power of appliances as base of sizing the system? a device that is rated 1000W is actually on average is just consuming 1000W/3600= 0.27W So why do I need 1000W inverter to drive such small load of 1W
Please assume the load is pure resistive load for the sake of simplicity.
