haycord
Hello. I am going to try to help a neighbor that already has sort of a piecemeal system that needs some serious TLC. They are on a very tight budget (he is a retired Vietnam era Green Beret) so I'm going to do my best to help pro bono. To begin:
They have one 1000W 12V Solar Array split into two 500W Arrays, two 40A PWM Controllers, a common 600AH AGM Battery bank, and a 3000W PWM Inverter (connected to the Battery bank). Fusing, cable sizing, etc., looks okay at first glance. One (of several) concerns is how to auto-disconnect that giganic Inverter before it sucks the guts out of the battery bank. It has a built in fixed alarm at 10.5V and a disconnect at 9.5V, neither of which are of any benefit obviously. I am cautioning them about limiting the Inverter Load to less than 1000W regardless of its 3000W rating. They know zero about the care and feeding of what they have so I'll be helping with that along the way.
To my first question: I'm not able to find a programmable LVD that can handle the supply current to the Inverter. I'm thinking of building one with a Powerwerx LVD-35 driving a (Amazon of course) '12V Continuous Duty Relay, Relay 250A, 5 Pin Starter Relay, SPDT High Current High Power On/Off Control Relay, Split Charge Heavy Duty Relay Switch, Coil 1.8 Watts'
Am I making this more difficult than it should be? Thanks for your help.
