24v 2P8S 360Ah
MezzBatt
Can I get some recommendations on BMS's for my config please. What are you guys using that have the same config as this..?? I would like a BMS that has balancing ability as a feature not just monitoring if this is possible..??
High current BMS are challenging. Personally, I would likely split it into 2X 8S batteries each with their own 100A overkillsolar BMS on it.
Agreed. That's what I did. Two 4s batteries, each with a 120 amp Overkill Solar BMS.
if you put the 2 sets of 12V 120 amp BMS in series to get 24V with this solution you are limited to 120 A ?
I still don't know if the only solution for 300+ amps is a small BMS that drive a contactor/relay, I was hoping to find a relay that has an initial load to be activated and then some mechanical advantage (spring or something) that keep the contact close but not a stupid magnet field that has to be always energized killing my battery :(
2X 8S batteries, each with an overkill 8S BMS, in parallel could handle 200A. Additionally, the overkill is rated to 100% duty cycle (you don't need to de-rate from 100A), and it's very over-current tolerant.
This makes a lot of sense to me as an electrician I've seen what breaking high current ccts does to contact faces. Also it allows all cells to be monitored via BMS. Problem is I'm in the UK and doubt he is shipping this way..???
i was thinking you want to go 24 V , so you have to go in series with the 2 sets and that solution is not good for you
This will never work, the 'device' rating is still only 12v/120amp. You cannot double up 12v loads/devices/resistances to work in 24v mode it's only DC power sources (Batteries) that you can 'series' up..... Ohms law anyone....????
correct, that why I said "that solution is not good for you" because you can not do it :D , my point from the beginning was using overkill BMS is out of the question if you need 200A and 24V . Sure you can go with 2 overkill in parallel and have 200A at 12V but i think was not the first post was asking.
It's a 24v battery I'm using as per the thread title..... So it boils down to whether I go 2P8S or 8S2P (both 24v).
I had a similar problem, and after chasing a 250+BMS at the end I decide to go with electrodacus , I will let it do all the BMS and solar handling, plus I will have a more complete monitoring system, temperature sensor, diversion of extra solar production, will be way cheaper and reliable with more longevity then MPPT system, and also physically less space, I am still on the design phase but if you want to take a look at the design so far and give your opinion you are welcome.
  • schema elettrico electrodocus.pdf
