Visionquest
Picking a BMS is the last step in my 12v battery project. I will be using 304 aH cells from EVE. From everything I've read getting a high balance current spec (1 - 2 amps) and overall high current spec (200 amps) is my best bet. I also definitely want bluetooth connectivity. I'm trying to compare the following three BMS's and appreciate any insights and help on which is best.
1) https://xiaoxiangbms.com/product/4s-lifepo4-12v-100a-120a-150a-200a-amart-bms/ (looks like just 150mA balancing or "equalization" current?)
2) https://www.alibaba.com/product-det...html?spm=a2700.shop_index.89.8.7db6273e0Ast3U (can't tell if this really supports a 4 cell config since it doesn't show up in the table)
3) https://www.alibaba.com/product-det...a2700.wholesale.you_may_like.3.2d596450Ey0ZQy (this one seems to have everything I need
I've also noted that the Daly BMS has just 35mA balance current so I didn't include that. But I am a bit confused as to why there are so many BMS's with low balance current capability. Do they expect a separate balancer to be used with their BMS?
Thanks for the help!
Bob
Bob
