Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,479
Didn't find the thermal resistance easily for that; catalog link had that as a search parameter.
Large fin pitch of 12.5mm won't interfere much with air flow, should work decently for convection.
I haven't done anything in airflow analysis or thermal transfer, just "ohms law" with thermal parameters.
Forced air vs. passive will make a huge difference. My experience was something passively cooled (a vacuum pump) drawing a few watts was almost too hot to touch. With a tabletop fan aimed at it, it was stone cold. Our "Expert" said the pump's max ambient temperature spec limited the spec of our system to less than that figure. I attempted to explain (without success) that the part (a Pfeiffer pump) really didn't have a requirement for ambient temperature, rather case temperature. Once we determined case temperature in its specified 45C environment, by using a fan we could operate at higher environmental temperature such that derived case temperature spec was met.
