First off, and I haven't seen this mentioned, it has to be stranded cable, not solid! I see this mistake all the time. Unlike AC, DC runs around the outside of the wire, not through it, so one solid wire, no matter the size, will choke even a small load right next to the battery so the more stranding, the better with DC voltages.
This is an excellent thread because most people don't understand this basic fact about 12v, or DC current for that matter, and that is load and cable capacities for a given load at each voltage with the same length of a run. You learn fast 12VDC can cost a small fortune in cable depending on load, and how far and spread out the different loads are on the circuit. Here's a comprehensive listing of wire cost by size per foot, and the second link from the same site but showing battery cable instead, which is what you want. How far does one need to run at $4.50\ft times two? Remember you need a positive and a negative. Oh, and don't forget the copper connectors, they don't give them away with the wire my friends. Doing a little math might make one rethink their layouts to economize on the amount of copper cable required. Put your inverter right next to the battery because you can run 120 AC through a 10\2 or 12\2 150-200 feet without a problem depending on the load.
We stock THHN/THWN-2 Copper Wire in a variety of gauge sizes for your electrical needs. Available in spools or by the foot. Order today for fast shipping!
www.wireandcableyourway.com
We stock SGT, SGX, SGR & UL3311 Battery Cable in a variety of gauge sizes. Available in spools or cut by the foot. Order today for fast shipping!
