So 8 feet at 5.77/ft so what $50?I have 2 pieces at 4 feet each. For the DC side if no good, then when I buy an all-in-one inverter in the future, I can use this to go between it and a wall-mounted panel, then (which I already own)?
so you intend on using this for DC input to a victron inverter? No AC output has that capacity.
The cable entrances for my MPII have a little bend in the cables in there to make my 2/0 lugs sit flat.
The lugs on the PBC boards with insulation around it, it does have a little flex, but and constant stress isn’t good for a high current connection.
