I bought a battery box 'kit' from Alibaba which came with a 200a BMS, and these 25mm2 thick wires and an even thicker positive wire. (Photos attached).
I've also bought a new JK BMS but it wont come with these wires.
So my first question is, where can I buy these thick wires, with two connectors on one end, and a single connector on the other? Secondly, why does the BMS have these two connections and do I need to use them both or would one be enough?
And also, what size wire would the red one be in mm2 and AWG? It's about double the size of the black wires which are marked 25mm2 and it's marked as 300a
Thanks
Will.
Thanks
Will.
