Ok. I think I’m getting a better understanding.
1. Run aluminum, not copper. Except for the 2 feet between the inverter(s) and the main panel).
2. Make sure the inverters and main panel can accept the size line I use for the long run.
3. Adjust the Quattro so that the voltage at the subpanel is close to 120 volts after all is said and done.
4. Size L1 and L2 using 120 volts (up to 128), and 39 amps.
(Question-is this 39 amps at the end of the run per the calculator?-I think yes.)
5. I can safely size the neutral and ground wires at the same size as L1 and L2. Though it may be ok to make them smaller.
6. Use individual THWN because pulling bundled wires is going to be harder.
7. Use quality/name brand wire, not cheap stuff.
I hear the advice to size at 240 volts, and I don’t doubt you are right. But I don’t understand it well enough. It may be I have one Quattro and find it sufficient for all my needs. So I’d need to size for 120 volts.
Here’s where it stands
View attachment 198572View attachment 198573
