That’s only true for grid tied installations when optimizing for maximum annual power production. If this is an off grid application, it should be optimized for the worst stretch of cloudy winter days.About 40 degrees would be ideal year round, but usually you would lean towards better production in the summer when there is more daylight hours, so something around 30 degrees?
Consider this:
Tilt & Azimuth Angle: Finding the Optimal Angle to Mount Your Solar Panels
Learn how to find the optimal tilt and azimuth angle to get the most production from your solar panels.unboundsolar.com
So if I'm at North 40° then I should tilt my panels to 40° up from the horizontal?About 40 degrees would be ideal year round, but usually you would lean towards better production in the summer when there is more daylight hours, so something around 30 degrees?
Consider this:
Great calculator but I'm confused about the Installed peak PV power [Wp] *Look at the calculator in my signature block and play with some numbers And see what the best tilt is.
Not counting AC, my power production is by far the most on winter nights because of the propane heater blowing and the electric it uses. So, I may tilt higher for that December shortest day of the year. If I do get my AC working on solar, panels will be flatter because I use the AC in the summer months. AC takes so much more than everything else, I would not worry about winter production because there’s be so many panels that in the reduced need in the winter months, any angle would work.
Kind of comes down to an energy audit based off low production verse high production to include at different times of year.
Well, according that guy it's something like 38° x .76 + 3.1° = 32°Here's a site that has been around for quite a while. I think it is a little to nerdy, and probably overkill for trying to figure out the tilt, but it is hard to argue with the logic: https://www.solarpaneltilt.com/
My place is at about 38°N latitude, and we pretty much only use it in the Summer. We went for about a 40° angle, and it has been fine.
I'm trying to figure out optimal fixed panel tilt
It depends on what you are trying to achieve and the sort of system you have.What angle would you suggest?
A very good point concerning the usual better part of the day for weather- more westerly orientation.It depends on what you are trying to achieve and the sort of system you have.
Optimal for what exactly?
There is a panel orientation which, provided there is no barrier to loads, will provide the highest annual output. That fine for grid tied sets ups with good feed in tariffs. But off-grid it may well be sub-optimal as it's more important to have power when you need it.
Without knowing what your needs are and the sort of system you have or propose then the answer is "it depends".
It may be more important to sacrifice overall production total to have better output in the Winter. Or to have a more even spread of production across the day. Or be able to recharge batteries earlier in the day, or cover aircon use in the late afternoon. Perhaps your location experiences morning fogs a lot at times of year you really need to extract the most, and it's better to face panels a bit more West rather than waste the end of the day with clear sky. etc etc
... Or to have a more even spread of production across the day.
For that, multiple orientations.
A single orientation will have a curve of production that falls off when sun is at an angle.
Two PV arrays oriented at 10:00 AM and 4:00 PM will present 0.7x as much area toward the sun but have a more broad curve, flatter on top. It can deliver 1.4x as many kWh/day for a given peak power. These arrays could have separate SCC (or MPPT input), but can be paralleled into a single one for better utilization of the electronics.
Delivering more power early and late in the day means battery kept fully charged longer, starts recharging sooner. Smaller battery is sufficient to get through the night.
PV panels are cheaper than batteries, so good to over-panel and buy less battery. But limit max charge current to what battery can handle.
Looks like your system losses are different between the two reports.To summarize:
-Depends on what you are going to need power for. (winter vs. summer things). Optimize for that season.
I use the NREL PV watts calculator. SImple, flexible and NOBODY WILL CALL TO SELL YOU STUFF. My latitude is 40 (Philly).Rule of Thumb would dictate a 40 degree angle year round but 25 was most pracitcal for me. Interesting that Zero and 25 degrees gives me about the same kwatt-hrs in the summer time. From the attached comparisons it does not appear to make much sense for me to bother with tilt ups during the summer.
One of the advantages of using the NREL PVwatts estimation tool is that the simulated hourly production data accounts not only for your latitude and longitude, array orientations and tile, PV array and inverter characteristics but importantly it also accounts for the weather patterns typical for that location. e.g. seasons where morning fog or afternoon storms might be in play and not accounted for by sun charts.Solar Radiation Monitoring Laboratory Department of Physics
http://solardat.uoregon.edu/SunChartProgram.html this will help you calculate what you need.
I used before I built the adjustable tilt into my semi-fixed array rack.
