As stated above I purchased from South LAN store on aliexpress. Did not intentionally change the value but cannot rule out unintended, lots going on here and no empty/isolated work space. Either way, a factory default should have reset the value to default and did not. I have made repeated factory defaults on this attempting to make it restore the factory values, the unit nor software does anything to tell you the factory reset has been successful so since the values stay the same I can only assume it failed.Did you change that setting or did it come with a bad configuration?
Did you purchase this from Current connected?
If yes, you should let them know.
If one setting was bad on arrival, all the key/vals should be checked.
I have contacted South LAN store with an update on the current reading situation, also asked for a copy of firmware and a default value for my particular (250A) unit.
