kenkoh
In one of Will's video he said Renogy's batteries DOA so not risking.
Do you a 150 recommendation? or 200?150 not enough?
200 too much?
It's relative to my peak sun and usage.
Drop it. Won't even think about making. I'm still barely understanding fuse v. breaker.Do you want a drop in or make your own??
12v yes. Battleborn only 100ah. I'm already getting bunch of Battleborns.I was going to suggest raw cells.
I guess 12 volt, confirm?
For a drop-in I have to say Battleborn.
I'm making only 12v systems. But if Battleborn's 250ah comes I'll get that.You could get 2x battleborn its only 30 ah over spec.
This my first go. Will mentioned topping up a Battleborn making sure it's 'balanced', that put me off. But I'm studying it also, so maybe.You can connect 2 batteries in parralel an it will be 200ah@12volts.
12v. Battleborn only goes up to 100ah for now.I was going to suggest raw cells.
Thanks!Get a quote. https://www.rj-lithium.com/ . Get a 15% discount by mentioning Gary L Chafin (Lithium Batteries on Boats FB group). Many people are really happy with this vendor.
When two battleborn paralleled, they will be balanced on its own.This my first go. Will mentioned topping up a Battleborn making sure it's 'balanced', that put me off. But I'm studying it also, so maybe.
I know it's ridiculously simple for people here, but I'm trying to stick to just a single battery for now, still have a lot of learning to do, just about ready to build my 400w series 12v single battleborn. I found it's actually not that straighforward to figure out all the safety stuff. Maybe in the future I'll do 24v.When two battleborn paralleled, they will be balanced on its own.
Especially when you buy two together, they will be matched and paired and ready to go. No need to worry about anything, just connect
