I want to begin by saying thank you for all your useful threads. I'm new to the LiFePo4/solar world and have learned a lot from you guys.
I'm building a 12V 304Ah unit along with a 200A JBD BMS for the tongue of my camper. I've seen many posts where a smaller, let's say 100Ah, battery is put into a weather proof case, such as a Pelican, and I want to do the same. The problem is that these 304Ah cells are pretty big when assembled and I can't find a case that will fit it all. Sure, there are the really big monstrosities with wheels, but I don't want or need wheels.
My dimensions with my compression setup are:
Side to side (terminal to terminal direction) - 8.25 inches (209.55 mm)
Thickness (the 4 cells packed together) - 14 inches (355.6 mm)
Height (bottom to top of post) - 8.75 inches (222.25 mm)
Does anybody have any suggestions for a waterproof case that isn't $300? I've spent some time searching and I'm coming up empty.
I'm hoping somebody has done this already and can share their findings. Thanks.
