John Frum
Tell me your problems
- Nov 30, 2019
- 15,230
If its configurable enough and part of the bms then its fine.I mean the BMS has the feature on by default, set at 2amps. You said earlier you wouldn't use an active balancer unless absolutely necessary... which suggests I shouldn't use mine. So I am trying to understand why. (other than the phantom load angle - which is a good angle)
Its the discrete stupid ones that I object to.
I suggest you make sure that your active balancer only balances above float voltage and only when charging.
I'm also ok with it balancing during charge and discharge but then I would have to get more specific about your charge profile including float voltage.
Which means I would need to know the specifics of your charge profile.
