18KPV Follow Up with JK Inverter BMS
Henderson
Hi all. It’s been several months since I posted my review of the 18KPV inverter entitled “My Experience with the 18K PV Part 1 https://diysolarforum.com/threads/my-18k-pv-experience-part-1.70933/
Sine that original post, the 18KPV continues to work with zero problems. As stated in my previous review, I have been using the 18KPV in lead acid mode with my DIY battery (a single 2P16S setup using 32 CATL 302Ah cells for approx 30KWh of capacity). This setup was being used with a Daly 500A BMS. The 18KPV in lead acid mode works flawlessly.
I had promised that my follow up review would’ve dealt with the 18KPV communicating with a DIY battery using Daly and the JK inverter BMS.
Well, there’s not much to say about the Daly. The Daly simply did not communicate with the 18K PV despite my best efforts and trying to get support from Daly. The Daly folks tried to be helpful but the Daly BMS just wasn’t doing it. I’m sure there is someway for this to work with communication but that way simply escaped me. And what makes matters worse is that Daly provides almost non-existent useful documentation on their products. Even their youtube videos are not detailed enough for the DIYers.
I recently added an additional 30KWh DIY battery for a total of 60KWh capacity, so I now have 2x 2P16S DIY packs each with 32x CATL 302Ah cells.
I have a 200A JK inverter BMS connected to each of the 2 DIY packs wired in parallel. The JK BMS simply worked…first time with no headaches. The 2 JKs in parallel works well together with the JK master doing all the necessary calculations for the entire battery bank and communicating that to the inverter.
The JKs are loaded with firmware version 15.17. In this firmware version I’m seeing LuxpowerTek being supported in addition to Pylon. I’m not sure if earlier versions had the Luxpower support but 15.17 certainly does. Both Luxpower and Pylon protocols on the JK work with the 18KPV, which is not surprising given that the 18KPV is a Luxpower device and Pylon is broadly supported by many different brands of inverters. For the 18KPV, I chose option 6 under Lithium when LuxpowerTek was selected at the JK and option 2 when Pylon was selected at the JK.
I was hoping that I would see individual cell information on the 18KPV screen or via the web portal but I am only seeing summary information in terms of total KWh capacity and what remains. The 18KPV also reports what the total charging and discharging maximums for both JKs and the amount of power currently being charged or discharged. Seeing the individual cell info on the inverter isn’t a big deal but it would’ve been nice. I’m not sure if the limitation is the 18KPV or the JK sending the information to the 18KPV or even if it’s at all possible.
I’m really happy with this 18KPV and JK combination. Next step will be to add Solar Assistant so I can have access to the JKs remotely. I got a bit spoilt with web remote access to the BMS when I was using the Daly with their wifi dongle. I think wifi is the only thing the JKs are missing. Other than that, the JKs are working really well.
You can easily solve even this with like $10 in components you can order online.
look into this:
And
Screenshot of my setup in Home Assistant:
look into this:
And
The new JK PM BMS is not yet supported by these solutions, my JK PB BMS is on 15.17 and I connect to it via Wifi using a HiFlying EW11 with a Virtual Serial port on the PC so I can connect and monitor the batteries anywhere on the local Lan. Once one of your solutions adds the JK PB BMS I will try them out. They are working on a solution but have not released it formally.
When JK introduced the PB BMS series they changed RS485 protocols and the Uart port acts differently too.
look into this:
And
Thanks
Thanks for the feedback. For the Daly solution, there's actually an app that you have on your phone that allows you to control the BMS. Looking for something like this but your solution can work as well.
I would love to see what the 18KPV screen looks like when paired with the EG4 power pro batteries, in terms of what information is being displayed on the 18K PV screen, the mobile app and the web portal. This would be a really cool comparison to see how a DIY battery compares to the power pro EG4 native batteries.
The JK PB has an android app vis Bluetooth and a windows app via rs485, other JK bms use the same apps.
Yes agreed, I have the JK bluetooth app on my phone. What I meant was, the app I had from Daly, I can access the BMS from where ever I am. For example, if I'm traveling, I can easily pickup my phone and see what the BMS was doing as the BMS itself has a wifi dongle that allowed me to connect to it from anywhere in the world directly, without having to utilize any remote connectivity options to a PC. It was just really convenient having that type of native access.
Even the latest PB series is confirmed working with the dev branch
also this relavant thread on syssi's repo as well. https://github.com/syssi/esphome-jk-bms/issues/390
Hello,
Recently i have buyed another pack o battery and i am planning to switch BMS to 2 pcs PB2A16S20P. Unfortunately for ESP WROOM32 and C3 boards Sleeper85 code is not compile successful and i cannot test. I am waiting for a release version for WROOM or C3 Boars as i have many. His code is optimized for ATOM S3 boards which i don't have.
For JK PB2A16S20P BMS i have tried syssi code and is partially working for me. I can see cells voltages, wire resistance, temp ...but i cannot use switches if you need just that syssi code is fine.
I also have tested Txubelaxu code here and is also working similar to syssi code. Just the infos, i cannot activate or deactivate switches.
All the above test were made with using a ESP32-C3 board
For JK B2A20S20P i am using Sleeper85 code here and is working great for over 3 months using a regular ESP WROOM32 board and a TJA 1050 CAN board connected to my Deye inverter talking under Pylon protocol.
@Henderson So this thread confirms the new JK Inverter BMS can have multiple linked in parallel and metrics available to 18kpv. Do you happen to have a diagram on what BMS ports to use when linking if the parallel packs?
I use RS485-1 RS485-2 for paralleling two JK PB BMS's
My Bad, RS485-2 either socket.
Master photo shows yellow battery coms, black PC comms and orange Canbus.
Slave photo shows yellow battery comms
However you can change the RS485 protocol on RS485-1 to JK Ver 1.01 RS-485 and then it would work.
@kommando Ok, think I've got it:
Slave RS485-2 -> Master RS485-2 -> CAN RS485-1 -> Inverter (BMS/CAN)
Is the above correct? I've got 4 of these inbound tomorrow to use with 4 105AH packs (replacing non-inverter JK's). I'll just chain the other two on the RS485-2 ports.
Yes you are right. No need to worry about which socket to use within the two twins as they are common wired on the board. Just keep Canbus RS485-1 and RS485-2 separate but within each pair the sockets are common. Use RS485-2 to connect to a PC via a USB485 adaptor so you can use the JK Windows app to update the firmware, I would have nothing else connected and the DIP set to 1 for the firmware update. If you set the DIP to anything other than one then you cannot update the firmware. I use firmware 15.17.
The BMS voltage is calibrated at rest, BMS amps is calibrated at charge. Calibration is important for the SOC calc.
I think this has to do with the in-built TWAI (Espressif likes to call CANBus that) peripheral support. ESP32 and ESP32-S3 have TWAI and that's why they work.
What we definitely know that the CANBus code won't work on ESP32-S2 because it lacks one. Regarding C3 or any other variants, you have to figure that out.
Edit: It turns out I was wrong and C3 does have TWAI. So the problem is somewhere else.
But the S2 has it too!
Very cool, appreciate the information very much.
I have no hair left on my head to pull trying to get EG4-LL to talk to 18kPV. I don't care about WiFi. I'm not putting any of my stuff on network. I'm smarter than Hezbollah and in the future my smartphones will be inspected before I use it.
I'll try the JK BMS and forfeit the warranty. It's only 15Kwh. I have 32Kwh coming Monday.
I would not assume you are smarter than Hezbollah. Hezbollah is known to have fully disassembled AND x-ray'ed multiple pagers/radios that had explosives in them and who knows what else to examine them to make sure they were safe and they did not find the explosive. The people that designed/build said pagers knew they did this, and had to have done a lot of careful testing to figure out exactly how to hide the explosives from all reasonable steps such that they could not be found. Consider that the explosives could be inside the battery, inside a capacitor and/or inside one more more ICs, and the signal could be something odd happening on the voltage/ground wires. About the only way to find it would be to completely reverse engineer the entire circuit diagram and figure out what component and/or wires should not be there or otherwise makes zero sense to exist.
@kommando Which port goes to the inverter then from the master BMS?
However you can change the RS485 protocol on RS485-1 to JK Ver 1.01 RS-485 and then it would work.h
Meaning, the orange cable goes from the master BMS to the inverter, correct?
OK. Thanks. Hi by the way. I have everything wired up correctly but still don’t know why the inverters are ramping to 70 Hz when I connect that 13th battery. I did test and added terminators everywhere but that didn’t actually change anything. JK says I should try their 15.38 firmware but I don’t really wanna do that until it’s the last resort.
Sounds like a combo of SMA having a failsafe when the Canbus get garbled and the 13th battery causing the garbling.
Finally the sun has come back and the batteries got to do some balancing after 4 months, one took a couple of hours to rebalance rest took 10 mins. So the cells are confirmed as good and the JK did not mess them up over winter with low charge currents.
OK. Rob Bob 2112 mentioned something about getting a CAN repeater. Do you think that might help?
Good to know your batteries are balanced well and interesting to see it that it was so quick. Mine get to 100% almost every day, but they’re still well under the 0.01v balancing limit.
Only way to fix is to sniff the canbus messages with 12 and 13 batteries and compare, but you only get 30 secs for the SI to then go to 70hz so you need grid backup.
