Please share us your experiences if you used it specifically if you connect it to a large inverter or capacitive loads also if used directly or via DC/DC to power up dc motors!Here's one of the contactor. Mine just arrived in the mail today even though the tracking says it's still 3000 miles away. It is indeed a Kilovac or TE contactor (at least according to the label ?)
edit: here's a spec sheet that seemed maybe a bit more useful.... It claims that (if these contactors are genuine) the power usage should be ~1.7watts https://www.te.com/commerce/Documen...200_Ser_Contactors&DocType=CS&DocLang=English
Is your wiring done the same way as in this attached picture?Can anyone help with the wiring if this bms? I wired everything according to the directions but it is not detecting that it’s a 16s battery
Yeah I did. It was just throwing me off that it was still showing cells 14-17 at zero. I thought it would mess with everything. But apparently that’s what it’s suppose to do. So everything is working good now!Wire the leads for 14 - 17 together and attach them to the third highest cell. In your case 14
Did you just receive one of these from Docan by chance?
That’s how I have it wired. Everything is working now. Thanks for the diagram!Is your wiring done the same way as in this attached picture?
I’m pretty sure it’s supposed to show that you only have 16 cells and not show the 0v readings…Yeah I did. It was just throwing me off that it was still showing cells 14-17 at zero. I thought it would mess with everything. But apparently that’s what it’s suppose to do. So everything is working good now!
Yes the cells that aren't there should go away completely (so not being present and reading 0v or so)I’m pretty sure it’s supposed to show that you only have 16 cells and not show the 0v readings…
Where did you source your bms? I got one from docan power and it has a generic looking contactor with no TE sticker or scannable code.
They are supposed to come with an IHV200 contactor but I’ve seen some people get EV200. I’m skeptical about the one I received.
I got the cells to go away! I had 14-17 attached to the wrong cell. I just got mine from docan this week as well. Mine has the little bar code on the contactor to scan but isn’t working. Should I be worried about it? Also does anyone have recommendations on a lcd display that will work with this bms?Yes the cells that aren't there should go away completely (so not being present and reading 0v or so)
I bought two at once, and one has a sticker on the contacter which is an EV200 and the other doesn't have a sticker at all.
Otherwise, they look exactly the same.
Nice!I got the cells to go away! I had 14-17 attached to the wrong cell. I just got mine from docan this week as well. Mine has the little bar code on the contactor to scan but isn’t working. Should I be worried about it? Also does anyone have recommendations on a lcd display that will work with this bms?
Interesting. Good to know the contactors at least appear to be TEsYes the cells that aren't there should go away completely (so not being present and reading 0v or so)
The fuse should be attached as close to your main positive as posible. It’s 400a cause the bms can handle 500 - 600a bursts according to the data sheetsBy the way, for each BMS I got a 400A fuse with it (the BMSs are the 200A version). I am unsure why it is, there is no place to mount them.
And of course I already planned to have other lower rated fuses anyway.
Read above comments. Wire all the leads you aren’t using to your THIRD highest cell, together with the lead for that cellI am getting a bit annoyed by now, I can't get the 15th and 16th cells to go away.
I have measured the resistance from the start of the balance circuit for the 14th cell up to the 20th cell, which are now all wired together, and they all read the same resistance value.
In the app I can see the 0.003v for 15th cell and 0.28v for 16th cell, which are not present on my 14s system obviously.
Another thing that worries me is that it seems to reset a bunch of settings depending on the amount of cell detection.
Maybe the limits you set stay that way, and are just multiplied by a different s number whej it automatically sets max pack voltage and so on.
In the app I cannot disable the automatic cell detection. Is this perhaps configurable through pc desktop or through another app?
Edit: Ah, I was misreading the whole thing, from the manual I now get that only the top two (red) wires should go to the highest cell positive (equal to battery positive) and the lower remaining ones should not be connected to the highest positive cell but to the second highest.
So by changing that I got it down to 15s, now it is seeing the 14th cell with 0.002v.
I'll keep on tinkering.
Yeah I saw it now, and also in the manual.Read above comments. Wire all the leads you aren’t using to your THIRD highest cell, together with the lead for that cell
But here are some of my questions about this BMS if anyone could answer I would be appreciated:
1- In the user manual is mentioned that using these BMSs in series or parallel are not allowed? Why ? because there is 900V, 500A contactor ! it is not mosfet based bms that limit you on drain sorce voltage limitation! or sharing equal current of multiple parallel mosfets for parallel connection!
I want to know if someone use it to series up to 4 x 48V , 100A pack still is not allowed to series these packs?
Ok I used this BMS parallel, 2 times a 10kWh NMC block. I didn't like it.
It might look like parallel is better with the relays but now I think it is actually worse. Because a purely MOSFET BMS is contentiously busing with monitoring and possibly limiting current. When the relay is open, it just goes.
Which is fine if they open and close at the same time. The design was as such that the corner cases (low and high voltage thresholds as well as temperature) would rarely occur.
However in real life they were not that in sync. That may have had to do with start up scenarios (inrush current to an inverter)
Anyhow, I witnessed way too much out of sync behavior resulting in balancing currents between the two 10kWh, to often.
I switched to a CAN bus system, monitoring all cells and just have one central activator for opening/closing the relays.
This was more expensive of course, but I will never waste time again trying to parallel with these kind of relay based BMS.
Every occurence of Chinese BMSs being used parallel are always mosfets I think, typically in solutions that are meant to be paralleled. (like server rack batteries etc)
So it is defenitely possible. However, not with this BMS and I have found that the cheap price is causing me to burn more hours into it. So from now on, I will only use higher grade CAN bus BMS for paralleling NMC.
