I like temco welding cable for the minute. (made in usa)
To help in searching do note that the brand name is Ancor, not Anchor. Darn spellcheckSuch as Anchor
What would folks prefer when it comes to choosing the cable type for their system?
- single insulated battery cable
- double insulated battery cable
- welding cable
The actual multi very fine stranded wire is the same identical stuff, so its only the insulation that is different.
I got the 1/0AWG size of the "slightly less heavy duty version" of those FTZ lugs. They are really good. Very recommended. I bought a lot of my electrical stuff from Bay Marine Supply. Great place with good service and prompt technical support.I've purchased these in past and are the best lugs I've used. Very high quality beefy ones. My 2/0 die that works well on my older lugs could not properly fit it because it was that much thicker. There is also a slightly less heavy duty version with flared end to make it easier to get all those strands in from those high strand count cables.
