I'm kind of surprised you unpackaged it, I would've been tempted to put the new inverter up FS after your previous experience!any recommendations which firmware is the stable one to use?
I've updated to the latest (1.03.11 and 1.04.09) and apart from the initial glitch requiring a change in power locale - all has been good. It's been feeding data to the solarman console (pro.solarmanpv.com) reliably for about ten days.any recommendations which firmware is the stable one to use?
I have 3 fire extinguishers standby and wear glasses!I'm kind of surprised you unpackaged it, I would've been tempted to put the new inverter up FS after your previous experience!
Mine shut down right at dawn as before for the 5 minutes. I also have not had the data stream shut down, yet. knock on wood. That and maybe a bit better synce with the grid are the only things I have noticed improved.
The battery issue seemed to resolve after about 20 minutes.
I now have 2 of the 4 mppt strings hooked up , each with a DC disconnect.I happened to be in the basement around 5:30am this morning and I noticed that the unit rebooted about six times in a row for the testing. The power didn't go out to any of the panels (or if it did, it was very quick).
How many watts total is the array?Good morning, I am testing the inverter off-grid with one string solar panels and one lithium battery connected via CAN. For some reason, the inverter only charges using the solar panels for around 30 minutes and then stops giving error "bus over vol". If I do full restart of the inverter, it charges again for around 30 minutes before stopping again. I have firmware version ARM V1.03.11 and DSP V1.04.09. Anyone an idea what could be causing this?
The array power is only 2.2kW. So max charging would be 40A.How many watts total is the array?
In 1. Setup>2. Grid STD>1. React Mode>What is your setting?
How many amps are you charging with?
Reason I ask is I have reported the issue with Bus over VOL and Bat over Vol. Been testing and I used Power Factor instead of React Power yesterday. Ran one day smooth as butter. Knock on wood.
As far as charging I had seen similar but only spikes where the charge would quit but picked right back up without any Warnings. I am about 400 watts over paneled on each three arrays. I covered a few cells on each array and seem to help. I also found that with V1.04.09 I can only get about 70 amps before I have drop outs. Before the update I had gone as high as 140 amps without issue. Ran 100-125 for months, again without issues.
Curious to see if we can narrow down some of these issues and understand some of the setting more fully.
I chose Power Factor and then returned out of the menu.The array power is only 2.2kW. So max charging would be 40A.
Our setting in
-> Grid STD> US-CA
-> Run Setting> React Mode> React PF> C0.100 (factory setting)
-> Run Setting> React Mode> React RP> 0 (factory setting)
Not sure how to use Power Factor instead React Power?
Can you elaborate what you mean by using PF instead of reactive power?How many watts total is the array?
It's my assumption that the four choices are modes? So each is a choice or mode instead of settings that the inverter used from each one. I don't have a clue what QU Wave and QP wave are. In Reactive mode I feel and seem to notice it is the reaction time that the inverter uses to changing loads, especially with anti reverse. When a resistive load turns off I noticed the inverter over shoots and feeds into the grid for a bit. I was worried about this so had Reactive power to +10? I think. But it seemed like the power fed towards grid, and that fed into by grid, jumped around more. Back to PF mode it seems that while it still over shoots, overall the changes look much smoother when looking at external monitor.Can you elaborate what you mean by using PF instead of reactive power?
Just to clarify, you set React PF> C0.100?I chose Power Factor and then returned out of the menu.
Yes, just left it as it was. a C0.100.Just to clarify, you set React PF> C0.100?
NCS; I am late to the conversation. I just installed my inverter and having this same problem. Kindly offer a solution if there is one.Does anyone know the firmware version # posted above? I finally got my unit powered up yesterday and the versions that came loaded are:
ARM: V1.03.06
DSP: C1.04.06
I'm told there is 'supposedly' a firmware update coming that will allow parallel of these units, but no idea if that will ever come about.
This one is the same
Hello All, I am looking for a digital copy of the megarevo 8kw owners manual? Any suggestions?
Was there another update since the firmware update from last month?I was lucky enough to obtain a copy of the latest firmware (Thank you!) and have confirmed that parallel function is now supported for these inverters. Unfortunately, I only have 1 inverter wired up right now since the parallel function was not available when I did the initial install. I'm going to try to get the wiring updated this week, so that I can test out the additional feature and report back.
