OffgridMatty
I know enough to be dangerous!
I have a small off grid cabin solar system. I am running a single growatt 24v 3000w inverter/charge controller. I have three 375 watt solar panels in series. I currently have 1 EG4 lifepower 24v 200ah battery with 5.1 Wh capacity. I don't have a server rack system due to space issues. I need to add a second battery and need to connect these through a bus bar in parallel. What amp rating should I make sure the busbar has to be safe? I am only running a max of 600w at any one time while reviewing the system output. I'm fairly new to all this so your help is greatly appreciated! Matt
