Hi,
I'm looking for input to confirm my RV batteries are wired in parallel and wired correctly for the solar controller and plug. I received it this way. I can not see behind the battery switch and assume both positive wires (from the battery) go to the same terminal on the battery switch essentially connecting them.
Thank you
Thank you
