mikeyoungvcu89
- Jul 5, 2022
- 44
I have a PowMr 5k inverter charger in my system which has been up and running for a while in an off grid cabin.
It seems to operate ok for the most part, I can power the cabin, startup generator to charge batteries if its cloudy for a couple days etc.
One question I have been trying to resolve since install is that if I test between the PV input neutral and any ground wire either in the inverter or the panel, I get a reading of 199v. This makes no sense to me but maybe it is completely normal. This happens even after I have measured total incoming volts at say..220v or 170v or whatever.
I do not have allot of confidence in this inverter and would not have purchased it if I had seen how limited the manual and support was. I really didn't know until I recently downloaded and read the EG4 manual.
I even tried contacting the seller, but received no definitive information. There is also contradicting information in the documentation. In the one sheet describing the inputs and outputs and operations it notes "Only the Live and Neutral wires will be connected to the Output Terminal Block, the Ground will be connected to the scre w terminal." I tried both ways but it made no difference.
I found other versions of this document which omitted this statement but included a statement about the requirement with lithium battery to first connect the PV turn unit off.. then connect the rest of the system.
At one point someone answered my question that it was normal to get voltage off neutral and ground on the PV.. another time I was told "something is wrong"
I am very experienced with AC power having wired multiple full houses but little DC background other than the occasional vehicle work.
I'm pretty certain at this point I will be replacing it with probably an EG4 but still would like to know.
