Hey all, I'm transitioning from 2 3000 EG4 inverters to a single 6000XP EG4 and have a question regarding my main panel hookup.
In the previous setup, I had a neutral-ground bond in my main panel, 2 hots and 2 neutrals coming from the 3000 EG4 inverters, and a chassis bond that was joined up in the main panel's ground busbar.
My thought is that I would leave it like that in the main panel, and just have 1 neutral and 1 ground wire that go into my main panel and disable the neutral-ground bond setting in my configuration. Is that reasonable, or should I remove the screw in the main panel and have the neutral-ground bond occur within the inverter and transition the primary ground wire from the main panel to the inverter?
