Sundog33
Sun Bather
SO, Ive had my new set up now for over a year. 200AH LifePo4 battery, Overkill BMS, Victron 100/20 and 200Watts of Solar in Parallel
running fine but wanted more solar to charge while I'm using power during the day.
I decided to add 2 more 100w panels and ran 4 in Series/Parallel to get 32v @ 12.4Amps and blew my 20Amp Battery breaker.
I then ran the 4 Panels in Series to get 64v @ 6.2Amps and blew my 20Amp Battery breaker.
I then removed 1 Panel and ran 3 Panels in Series to get to get 48v @ 6.2Amps and blew my 20Amp Battery breaker.
Then, I noticed that even though the Victron said I was getting the right amps (pictured @ 5.5amps)
my BMS was showing I was getting twice as many amps (pictured @ 11.27amps) This reading was not done in full sun, so it got higher and blew.
What am I doing wrong?? Why is the BMS doubling my amps?
