Is it possible to connect a second LCD screen to the inverter? I see another connection for it underneath and was wondering if one could stay on the inverter and another on a long cat 5 be set in another room for monitoring.
Unfortunately you cannot. You can hook it up to Solar Assistant and be able to monitor remotely. If you would like, however, you can attach a long cat 5 and run a single screen where ever you need it.
