Dr.Bannock
Hi, I am new to this forum, have looked around but could find anything about the fault 80 in combination with the EG4 6500EX.
I have a split phase setup with 4 x EG4 6500EX inverters, first 2 with a load center as Line 1 and second 2 with a load center as Line 2.
First and second inverter set as 2P1 and
third and fourth inverter set as 2P2. All are communicating.
There are 2 battery racks of 6 EG4 LL each connected in parallel to the bus bar inside the racks and to extra bus bars (positive and negative) and then to all inverters. Communication cable is connected to the first EG4 6500EX inverter.
To setup the inverters I had to give them some power from the solar panels. I connected all the first inverter of the 2 in line 1 with one string of solar panels, the second inverter of the 2 in line 2 with another string of solar panels and paralleled the power to the second of line 1 with the first solar panel string and the second of line 2 with the other solar panel string. (sorry, but I hope everyone understands, what I mean).
I am in the situation of the first time installing this system and finally got to this step, that I was close to start the inverter mode, but before I could do that a fault 80 occurred on all of the inverters. Pushing the on/off button doesn't start the inverters of any unit.
The manual says, its a communication problem (CAN data loss -> Check if communication cables are connected correctly and restart the inverter)
In another forum it is said, that a firmware update would solve a lot of those problems, but I also just have trouble to find a windows computer which lets me install the .exe files. My old windows laptop need to have a special driver installed, who recognizes the new device at the USB-Port. While trying to install the firmware and start the exe-file the error comes, that there is no real communication between the inverter and the computer. So I might try my linux laptop and get this .exe running in kind of windows environment like wine.
Before that I would very much appreciate any advice how to proceed, being so close to a real success story, when this system will run.
Thanks
Christian
Thanks
Christian
