zanydroid
Solar Wizard
There is no "double negative" , whatever that means.
It's just two 120v inverters connected in series.
Each one provides 120v. And together, they provide 240v.
The 120V inverter have a common neutral. Let’s label these the top inverter and bottom inverter, corresponding to L1 and L2.
If you configured both inverters to output with no phase difference with each other, the L1 to L2 voltage is 0, this is the config that OP wants
You need to set a 180 degree phase difference to get split phase
BUT. The way the double negative comes into play is that the top and bottom inverters are not in series in the same direction. If they were in the same direction then the bottom inverter would be set to 0 degrees.
What would you configure the degree difference between inverters for two parallel 120v based on your notation?
In a Wye setup would you program the inverters to be 120 degrees apart or 30 degrees?
