I have an off-grid 6000ex (no grid in/out) that has the AC out connected to a main panel/load center. The panel has a ground/neutral bonding screw like the one shown in this image:
![ground-netural-bond-screw.jpg ground-netural-bond-screw.jpg](https://diysolarforum.com/data/attachments/121/121300-530782f42b7e1febe1c4de8b9ab7483d.jpg)
In attempting to learn more about ground neutral bonding I discovered that the LVX-6048 does ground/neutral bonding when in battery mode ( so for me all the time ) and assumed this model would be similar. (Signature Solar hasn't responded to my email yet)
If the two models do handle g/n bonding the same:
Do I have a double ground neutral bond? If so, what type of problems would that present in my system?
