Zwy
Emperor Of Solar
Hi Zwy,
Thanks for your suggestions. For reasons I don't understand, the Tesla universal mobile charger (UMC) only works when I connect the EGC to the main service panel ground and bond the N-G in the critical loads panel. I previously had a separate ground rod for the off-grid subsystem only (see rev 2 diagram below - I've since revised the wiring to what's shown in rev 3, which is the version you were commenting on). I'm now only using the auxiliary ground rod to ground the panels and it is not connected to the critical loads EGC busbar.
With the rev 2 wiring, the Tesla UMC kept faulting and current limiting to 8A. At one point, I had to use both the separate auxiliary ground rod and the main service panel cold water pipe ground to get the charger to work but it still current limited to 8A.
How far is the distance from critical loads panel to the ground rod?
At this point, I'd begin to determine if the inverter is bonding N-G. Most likely it is, removal of the N-G bonding in the critical loads panel, then attempting to charge off the inverter might reveal that indeed the inverter is bonding N-G.After disconnecting the PV+ and PV- per Summit's suggestion as shown in the rev 3 diagram, I was then able to charge at up to 25A. However, the Tesla UMC still faulted occasionally and throttled back to 8A before jumping back up to 22A on its own for unknown reasons. I also have a Juicebox EVSE charger but it won't work with any of the ground, NG combinations. It used to work when tied to the grid.
BTW, in the rev 3 diagram, the dashed green lines are not connected (forgot to annotate that).
Or open up the unit and determine if the ground screw is present.
