asmith66
See the pictures for my setup.
One 6500, two Lifepower 48v batteries, 6 455 watt panels, off grid system.
I'm trying to connect to the inverter to the load center. It ain't working. I have one test outlet wired and it's not getting power. Any assistance would be greatly appreciated.
In the attached photo:
One green ground to the inverter.
One green ground to the pv's and then to a grounding rod.
White neutral from inverter connected to the bus bar. Ground neutral bonding screw is inserted.
Black line from the inverter to double pole 60 amp breaker. Wire is connected to the pole that feeds the left side of the load center.
At the top I wired one wall outlet to a 20 amp breaker breaker. Both line and neutral go to the breaker and ground to the bus bar.
I am off grid and have only one inverter. Any assistance would be greatly appreciated. Remember, this is the beginers corner so reply back to me like I am as ignorant as I am. Slang, abbreviations etc might go over my head.
