Newbie here with a question about panel arrays and shading/wiring. I'm going to be using 8-200w, 22v, 10 amp panels in 2 arrays. Each 4 panel array will be facing the south and on the east side of my home. Both arrays will start to be hit at the same time by the shadow from my home in the mid afternoon, with the shadow slowly covering one panel after another on each array, as the day goes on. I've done some research but can't grasp which would be the best wiring scheme. Should I wire each array in series or parallel and then combine the two arrays in parallel to the controller or should each array have 2 panels in series and then parallel those 2 sets in with the other array. Hope this makes sense. I can then figure what size charge controller and wire I will need since the distance from the arrays to the controller will be approx. 50 ft. I don't have a specific power need. I am building this just to see what I can power with these panels using a 24v system with a couple SOK 200A batteries to start with until I figure out how much output on average I will get from these panels. Any advice or tips are appreciated.
