Dr Danger Stunts
I have a new Growat 12k and I am stuck trying to figure out how to correctly wire the panels in series parallel. I have 20 130 watt used panels. The max PV array open circuit voltage for the inverter is 250vdc and the PV array MPPT voltage range is 60-245vdc. There are two inputs for PV arrays. My brain is stuck trying to figure out which of the numbers on the back of the solar panel to use to calculate haw exactly to wire them up. I would like to know the best configuration for this please.
