Even if it s grid charge?If charging current, it's DC.
The battery charger charging current spec is what the charger can provide to the battery which will be DC current rating.Even if it s grid charge?
Deye inverter i want to know if i put my battery charge on grid is 100 let s say will take 100 A from grid or will be convert it to dc AmperWhich inverter, Which specs? regardless, battery current limits are generally specified on the DC side for the battery rail voltage.
Ok thx so if i put my grid charge battery 100A will be 10 ac current thx that was my questionThe battery charger charging current spec is what the charger can provide to the battery which will be DC current rating.
If you have have battery charger that get the power from utility, that charger will take the AC input and converts it to DC supply to charge the battery, for example the 12VDC 10A charger using utility can provide 10A of battery charging current which will be = to 120W, that means (for simplicity we will ignore conversion loss, and PF for now) if utility is 120VAC, the AC input current to the charger will be 120W/120VAC = 1A of AC current.
100a DC charging.Deye inverter i want to know if i put my battery charge on grid is 100 let s say will take 100 A from grid or will be convert it to dc Amper
So if 100A charge on inverter for a battery of 48 v lithium 100/48 = 2 amps on 220 v ac utility current right?The battery charger charging current spec is what the charger can provide to the battery which will be DC current rating.
Around 21 to 24 amps from the 240v AC.So if 100A charge on inverter for a battery of 48 v lithium 100/48 = 2 amps on 220 v ac utility current right?
100 A divided by 48 v batt = 2.08 A100a DC charging.
Can u put for me how do it from 100a to 21-24 amp on 240 to see the mathsAround 21 to 24 amps from the 240v AC.
That's not the correct math.100 A divided by 48 v batt = 2.08 A
Ok thxThat's not the correct math.
100a x 51.2 (nominal 48v battery voltage) = 5,120w
5,120w ÷ 240v = 21.33a
If 100 A charging battery on utility on inverter = to real A current will be?Watts is a consistent measure of work.
10 amps @240 volts = 2400 watts.
46.875 amps @51.2 volts = 2400 watts.
If that is clear then I will add some more math to make things even more realistic.
Assuming by real current you mean DC current from the charger to the battery.If 100 A charging battery on utility on inverter = to real A current will be?
If im putting 100 A on inverter as charging what will be how many A on utility ac amps ??$$$$Assuming by real current you mean DC current from the charger to the battery.
and assuming that the AC voltage is 230VAC.
and assuming that the DC charge voltage is 55.2VDC
and assuming that the charge efficiency is 80%.
100 AC amps * 230 VAC = 23,000 watts
23000 watts / .8 conversion factor = 28,750 watts
28750 watts / 55.2VDC = 520.833333333 DC amps
