Patrol
Hi, my 3 panels deliver 100.9 Volt, my Epever 30 A says it's to high...warning because 100V is max. How can I solve this little problem? Can I blind a part of the solar panel?
Best regards, Willem
You need to change the number of panels wired in series
No. That is not a good solution.Can I cover a panel slightly so that it has less yield?
Have you ever heard of anybody doing this?Put a few diodes in series with the panels, each diode will drop 0.6 volts.
Make sure they are rated for the current.
No, it not shuts the controller. Only the warning light flash, but in full sunset it stops and the voltage is 98 volt.Not much wiggle room. 0.9 volt and it shuts the controller down?
I have a fourth panel and also room for installation. Good idea!If you have room for a fourth panel. Go with 2s2p.
If not, remove 1 panel. It will only get worse in colder weather.
Consider yourself lucky that you got a warning.
There's no way to put the magic smoke back in.
YesCan I connecting 2 in serie and connect parallel with other 2 in serie?
Check with your battery manufacturer's recommendations.What are the most effective setting for the controller? I have MT50 remote.
Thanks, in advance.
