Hi. I want to use an all-in-one solar charger/inverter for a 48 volt battery. However, the standby power consumption of its inverter is 65 watts. So my plan is to only turn on the all-in-one inverter when I run a large device like an air conditioner (the only reason I am upgrading my system). But for other times, like winter when I experience 4 or 5 days or more extreme overcast skies, I want to connect a 48 v to 12 v buck converter to the 48 volt battery and connect the buck converter to a low consumption 12 v 400 watt inverter(will usually just run aprox 30 watts).
(It seems 48 volt small wattage inverters are extremely rare)
So my battery power should last much longer.
Can a buck converter be used to power a small inverter in this manner? Does buck converter have a high standby consumption which would negate the power saved? Thanks for your input.
