Carling Technologies MCCB mount and install
tonyg
Hello fellow solar friends!
Adding a second battery bank (EVE lf280k), I have bought two Carling Technologies F series hydraulic MCCB (https://www.carlingtech.com/hm-cb-f-series). However, I cannot find any details regarding how to properly mount this - I see very little information regarding different mounts.
I could diy a front perplex mount, but wanted to see what others have done.
With regards to the wire connection, it's first time I see such a cone connector. What js the best way to wire this in then?
As always,
Best wishes to all reading and thank you for all those responding.
Tony
The two half circle slots on either side. Are designed for mounting. (Long bolts to the mounting surface)
Those type of breakers are also sold by Midnight Solar with Stud connections. I have a 175A Remote Trip in the garage.
The breaker itself is panel mount and the 2 holes in the front are threaded. 10-32 screw??, not 100% sure.
The mechanical lugs are designed for bare copper (or Al sometimes) so you just strip the cable, insert and torque the hex screw to spec. Copper tends to compress a little and relieve pressure. I usually torque twice with a 5 min wait in between.
Brilliant, thank you everyone so much.
I'll be using the long bolts on the sides to mount them on a custom panel.
I've already un-bolted the current mechanical lug and it looks like an m8 bolt fits there, so I can put a proper compression lug there.
