Veteran52
- May 18, 2020
- 33
I have been given 5, 100 watt monocrystaline solar panels in good working order. I want to set up a solar storage systems based on these 5 panels. I've done some research and decided I want to use a MPPT charge Controller and given the poor ventilation of a confined space near a furnace, AGM batteries. What is the smallest amp charge controller I can use? 20a, 30a, 40a? If I use 12 volt batteries what should the total optimal amp hour rating be for my batteries with these panels? What size AC inverter would work best with this capacity? Thanks
