WattAboutThat
- Dec 15, 2021
- 123
I am installing Two (2) EG4 18kPV Inverters.
I am going to put Three (3) Strings to each inverter.
One string to each MPPT (MPPT 1,3,4)
Not using MPPT 2 (which is paralleled internally to MPPT 1).
Each string will have TEN (10) Canadian Solar all black 385W panels in Series, each panel is
43.9V and
11.32A.
I am not paralleling any strings.
I would like to have a combiner box
(even though not combining, just for preventive safety) at the solar array to protect from lightning and to have a breaker before it travels to the inverters.
So I am looking for
a single string combiner box,
that will have fuse, breaker, and lightning protection for each string, then send down the wires to inverter (which has an internal breaker).
So I am not sure if it would still be referred to as a combiner box.
I dont mind if it is a larger box that can have 6 strings in one box going in and 6 strings going out, I am mainly looking to have protection for the system, before it reaches the inverter(s).
I have searched with little luck.
My best bet so far is to get a Two String In, One String Out Combiner and just not use the extra string input. This would then require 6 of these.
I am requesting advice, ideas, where to purchase something for this purpose.
Thank you for your assistance.
43.9V and
11.32A.
So I am looking for
