WanderingAlbatross
- Apr 21, 2020
- 66
Will do! Nothing so far.
We'll see what this week brings.
If you take the quote, "However the company will not be responsible for free repair services for any damage to the product caused by the quality issue and improper operation of such third party solar panels even during the warranty period." literally, then all you have to do is provide evidence that there is no quality issue and that they were operated properly. I would be asking exactly what tests you must carry out to confirm to them that there is nothing wrong with the panel used, thereby proving the root cause failure being with the Ecoflow Delta.Here is the language from the manual regarding the "DIY" solar option:
I stand corrected, it appears to be a 24-month warranty.The Delta manual states that it has an 18-month warranty.
I was asked to do a few tests and then it might be sent back.
If your panel was not defective and your panel was withing the electrical specs and you connected it correctly, how can they say it was your fault and not honor the warranty? Seems the burden of proof is on them.Here is the language from the manual regarding the "DIY" solar option:
EcoFlow DELTA 1300 User Manual ï¼Multi-language versionï¼. pdf
drive.google.com
There are ways to test PV panels (e.g. Voc, Isc with a multimeter, bypass diode function, hot cells etc). I am assuming that your battery was discharged when you did your test ... you won't get power from a PV panel if there is no load.And the third charge? 35 Watts. What the hell ...? Is the EF panel broken? More tests, perfect weather conditions, the input was at maximum 49 watts. It's far from the 70 watts that give me the panel at first.
