tigre1su
I wanted to share an issue I faced when I switched from the EcoFlow Delta 1300 to the Delta 2 Max in my RV 12V system (which plugs into the Delta's 12V car/cigarette output). Some of the lights (some with dimmers, some not) began flickering, others were unaffected. I updated the firmware as advised by EcoFlow but the problem persisted, finally, after countless useless emails they advised me to use the AC output instead which I did by using an AC to DC 12V 150W converter. It worked, but as I said to Ecoflow, it is far from resolving the real issue or flaw at hand.
Wonder what may be producing this glitch, as EcoFlow is as lost as I am. My knowledge on solar and 12V systems is very limited.
