I plan to add a solar energy source to my older motorhome but the OEM energy management system is creating a concern about this addition.
These older motorhome have a so called BCC (battery control center) which is a solid state manager for the charging inputs from shore power, engine alternator, and onboard 5000W genset for charging the house battery bank and the chassis (starter) battery. It has its own logic for directing charge current to these batteries.
My concerns are many but let's start with the concern for conflict with the OEM BCC and the addition of the new charging supply of the solar system.
1. If I provide the solar power directly to the house battery bank, will the OEM BCC see anything other than the net state of charge of the house battery/solar input?
2. The chassis battery is a sealed Pb-acid battery. I'd like the house battery bank to be LiFePo4. Can these two disparate types coexist in this system?
3. Will the alternator require protection if I use lithium house batteries in the system?
