Hello,
I'm running and eg4 6500ex and 2 Lifepower4 batteries. Last night I shifted my house back to grid power before going to sleep,.leaving the batteries at 20% and the inverter on standby mode. The pv array was left connected. My thought was that when the sun came up thos morning, the pv input would wake up the inverter and it would begin charging the batteries.
You can see in the attached SO SOC graph that the battery held at 20 % through the night. Just before 8 it dropped, then back up to 20 briefly, then bottomed out.
I guess I have three questions. 1) did the batteries bottom out because the pv input early in the morning wasn't sufficient to cover the overhead on the inverter? 2) why did the inverter not shut down when the batteries reached 5% as programmed? 3) have I damaged my batteries by running them to zero? ?
Thanks.
Thanks.
