Could you clarify the new feature?In the newest software version 11.288 one of my friends bms, i found new features like SOC-0% and SOC-100% voltage. On version 11.25 this function not exist. So, should be the way to some how update software version to the newer one by rs485 port and PC, because by the app on IOS at least it’s not possible at the moment.
I tried to contact support by email with this question, still waiting for reply. Any suggestions?View attachment 179034
He has LG chem e63 batteries LI nmc from hyundai konaWhat chemistry is he running?
As I understand you set starting point Voltage and SOC 100% voltage of your battery. And between those two voltage you have 100% of your battery SOC. Assume that bms calculate Soc much accurateCould you clarify the new feature?
That sounds like SoC estimation by voltage.As I understand you set starting point Voltage and SOC 100% voltage of your battery. And between those two voltage you have 100% of your battery SOC. Assume that bms calculate Soc much accurate
I would like it if they would just set an upper pack voltage that would set it back to 100%That sounds like SoC estimation by voltage.
Yes, observed this as well..had to replace a damaged bms due to my carelessness..and the replacement bms didn't have the soc % voltage isssh. i use same phone for all my jk bmses, so the issue is hardware based on the bms itself, not software....As I understand you set starting point Voltage and SOC 100% voltage of your battery. And between those two voltage you have 100% of your battery SOC. Assume that bms calculate Soc much accurate
