At first blush, you seem to have 1 pack at a slightly higher voltage than the rest...
I will GUESS that you have the (+) & (-) coming off at the TOP of the rack busbar and THAT will do it.
Put the (+) at the top and the (-) at the bottom of the bars.
Then ensure that the wires from both are the SAME LENGTH Exactly to the common DC Bus and hen from the common DC Bus to the AIO's.
Exact length of the wires & lugs, Do Not Include shunts, fuses etc in the length.
I won't argue that... Shnieder, Victron, Midnite and other Tier-1 Manufacturers/VARS state the same thing and I believe the Engineers & designers and this has been proven to be SO TRUE in the real world. There is contention on this point which comes from YT Genius Wizbangs parroting twaddle they believe cause they saw it on video...
1 point to consider & understand. Every connection, fuse/breaker/lug etc ADD Resistance & line loss. That MUST be accounted for and corrected/adjusted to compensate.
The voltage readings at BATT Terminal & AIO will show that difference and IT IS DIFFERENT when Charging or just Discharging. Many Tier-1 products have offset setting to correct for such, I do not believe Growatt Basics have that, therefore you have to correct manually. Use at least a 2 Decimal Point Accurate DVOM/DMM and measure the voltage at AIO Terminal & Batt Terminals during charge & again at discharge, note the differences and adjust accordingly.
