If you suspect the battery SoC’s will be different (like if the batteries are different) then 2 would provide more info.Does it make sense to have 2 shunts to track SOC for each battery, or should I just do 1 for the entire battery set?
Can they be if same chemistry and connected in parallel?If you suspect the battery SoC’s will be different
For LFP, yes they definitely could be different states of charge at the same voltage. But does it really matter if one of your LFP batteries is at 50% and the other is at 70%? Almost certainly not.Can they be if same chemistry and connected in parallel?
3 weeks ago I would have suspected that they would charge and discharge similarly.Can they be if same chemistry and connected in parallel?
I have not had enough sun to get them charged much higher than 3.31V so I have some learning ahead of me.then once they are charged to 3.45V or more they'll both be at 99-100% ish and would then keep synchronised.
You should expect them to sync to the same state of charge at the top (as you note), and at the bottom, i.e. above and below the flat parts of the curve. But in the flat region, minor differences in the batteries, even if they're as identical as is possible (same connections, matched cells of the same age, same BMS, etc.) would mean that at a particular voltage, each batteries preferred SoC might be different.Interesting... I would have thought that a correctly designed system with same wire lengths to both batteries, then once they are charged to 3.45V or more they'll both be at 99-100% ish and would then keep synchronised. Be good to learn more about that as you observe more.
That is one of my favourites and I have pointed other threads there to read at least first 4 posts to understand the concept.I found this post interesting
