This is for a battery backup after hurricanes, no solar. I have a 12v 300ah LifePo4, an 85amp charger, and a 4000 watt inverter. I want to power a fridge and a freezer, a few lights and fan, all at night. Possibly an entertainment system. During the day, i will be running the whole house with a loud 9000 watt genny. I want to charge the battery during this time, roughly 5-6hours. The battery has 1/0awg cables, and a 350 amp t-class fuse. Should i connect this to a bus bar, which branches off to the inverter and the charger? Or, for component protection, should i consider completely seperating these with Anderson connections? I sort of like the idea of being able to move the battery and charger at times, to be plugged into my small genny. But i don't like the idea of sparking, and inferior conductivity. I am leaning bus bar. I realize inverters are left connected to solar systems, i am just wondering if there are advantages or disadvantages with either bus bar or Anderson connections? Any third alternatives? Can anyone recommend a 300 amp rated bus bar for this set up?
