Ketchgould
- Nov 1, 2022
- 39
I have a 3000 watt inverter and it calls for 10AWG wires on the 120volt AC wires to the house. There is an "overload" shutdown on the inverter, which doesn't exactly sound like a breaker. 10AWG wires are 3 times as expensive as 14 AWG wires.
I do not anticipate needing 30 amps at any of the outlets I am wiring. I am powering a 1.2 amp refrigerator for some of the summer months. The largest draw I anticipate is my Fein Turbo One vacuum (9 amps) with a sander attached to the vacuums 6 amp outlet for a total of 15 amps.
How would you wire this small cabin?
I have access to a 3 phase, 3 circuit panel. I was thinking of wiring the 3000 watt inverter a foot of 10AWG wire to the 3 circuit panel and then wiring 2 or 3 with breakers and 14AWG wires to outlets in and outside of the cabin.
Make sense to you?
Is this the simplest solution?
Thanks
Christian
Make sense to you?
Thanks
Christian
