midwestsolarnoob
Hi guys! I’m planning on ordering panels within the next month. Ive gone over several solar set up ideas on paper for the build. With this idea being the one that makes the most sense. I’m planning on my buying 16 100w panels. Basically I have the space to do 4 x 4 panels on a diy roof rack or roughly 160” x 80”. My mobile application is a Shuttle Bus we’re converting to a tiny home for traveling around the country. Roof is formed fiberglass which I’ve posted photos before. Reasoning for 100w panels is the generic 40” x 20” form factor. Almost all of them I’ve looked at are about that, give or take an inch. I’m also leaning towards the 100w panels for their smaller surface area per panel which should help with durability. And a 100w panel is a a lot cheaper to replace than a 400w. So my questions are as follows. And any advice is welcome as this will be my first solar build. I’m also leaning 24v for battery bank
1. What 100w panel brands are good enough for a mobile build? Renogy, Rich Solar, Eco worthy? Or any others brands worth mentioning?
2. Will I run into any problems with 16 panels?
3. Should I use 1, 2 or 4 charge controllers?
I guess my biggest concern is having problems on the road. I want to buy good panels but not over spend for a name.
Thanks for the help! I’ll definitely be looking for more help the farther into this build I get.
